Rich on e85 stoich
I want to see commanded Lambda equal actual Lambda.
Makes no diff if you choose to use AFR.
HPT accommodates either scenario.
Sure you can change the VE, shoot, you can just change commanded fuel until what comes out the tailpipe is good.
Anyway, OP’s car wasn’t tuned well on gas, so it ain’t gonna track like it should. And it isn’t.
ron
ron
Everybody has there way of tuning, and what they are familiar with. As long as its tuned correctly, using Lambda or AFR I wouldn't worry about it. If the tunes good, its good no matter what it took to get it there!
As for the OP, His car just needs a good tune on it. Something wasn't right before the switch to E. If the tune was correct the AFR would have followed the switch. All u need to do it just start tuning it on E. Everything will eventually fall in line!
ron
As I said, you can just change PE to get the tailpipe reading correct. You can change injector flow to do the same. Lots of buttons to push...…
You ought to see how folks tune the Dodges, which are all SD calibrations. Maybe you have.
At any rate, you have way more experience than me. I've followed you and your tuning for quite some time. You have my respect.
I've just seen so many hacked LS and Dodge tunes that I just stick to Banish tuning methods which I feel is about accurate calibration.
Ron
I’m still using the gas scale and choose to change stoich to the actual value for the fuel I’m using rather than hack up the VE table. I run E70 and enter 10.7 as my stoich. The only issue is it makes your AFR percentage error histogram look funky. For a shop doing a large number of vehicles and time constraints lambda makes sense. For me doing my own stuff and helping friends using the gas scale isn’t an issue. It’s easy to see on my histogram with a 10.7 stoich a 37 percent error using the gas scale is dead on while higher error is lean and lower error is rich. Not hacking the VE makes sure all other calculations are correct. No issues with an auto trans and even my delivered torque calculations seem dead on.
10.7 stoich divided by 1.28 equals a commanded 8.359 on E70. Since my wideband reads on the gas scale that equals a 11.45 afr. 8.359 X 1.37 equals 11.45 so a 37 percent error is dead on while a higher percentage is lean and a lower percentage is rich. It works for me. LOL
Note that increasing VE has other side effects...
this causes the DYNAIR g/cyl value to go up, this then references a different column in the spark tables...
both of those cause the engine toque calculation to change, this causes trans line pressure to change.
