erratic idle
I have put 2000 miles on it since the tune. I have a wideband meter and when it gets erratic the AF varies from 13 to 16. When it is idling smoothly it has much less variation.
I am not a tuner but I would at least like to know what the problem might be before I take it in.
I should also mention that it has always hated to drive in 1st gear at anything less than 1500 rpm. It surges a lot. Before and after the tune was the same.
"I have a wideband meter and when it gets erratic the AF varies from 13 to 16"
Do you know if the tuner turned off the cylinder misfire codes? Are you sure it doesn't have a mis fire or dead cylinder? If you have a infared temp gun, hit your headers once its up to temp, and see if they are all close in temps or not.
