Logging Problems With HP Tuners
Has anyone else had this issue? How can I fix this? I have recently upgraded the software through the HPTuners web site. Could it be a problem with the software? How can I revert back to the older version of software as a test?
I will attempt to post a log here...
So freakin weird. After posting, I clicked on the log file and when I play it-IT'S NOT DOING IT ON THE REPLAY!!! You can't see it on the log file, but if I plug in the LTFT's just sit there spiking up & down non-stop. How is that possible. I can take a short video with my phone and post that up. It WILL show what I'm talking about. Crazyness.
Since you are looking, can you also see that one of the O2 sensors is basically sitting at ZERO, and the other is almost at 900MV most of the time? Does this indicate the O2 sensor is bad? They are both brand new. I would think the one sitting at zero is the issue.
Can't turn the FT's back on though without fear of it falsely reporting the AFR and adding excessive fuel again. I will post a log, and the tune, in the morning. I need to figure out if it's a wiring/O2 sensor issue, or an HPT logging issue.
