343 code please help
Old Sep 10, 2018 | 04:42 PM
BluBird98's Avatar
Default 343 code please help
I have a 1998 WS6 Pontiac Trans Am. it's all of a sudden throwing a 343 code, I have changed cam timing sensor, let me clarify this I have changed every sensor on the motor check continuity on all the wires and still throwing a 343 code high voltage. I now have changed the ECM and still doing the same thing 343 code I'm lost. Thanks Jim
Old Sep 10, 2018 | 07:02 PM
truckdoug's Avatar
what voltage does your alt put out at idle? can you observe logged PCM voltage? are those two things close to matching?
Old Sep 11, 2018 | 12:47 PM
BluBird98's Avatar
I will check those two things thanks.
