G/CYL question
Right now, I am trying to get the timing table dialed in but not sure what cells in that table are being selected for boost levels vs RPM vs, IAT, etc. The timing table of course has g/cyl & RPM on the axis. Is there a way I can log this to show which cells are being used for timing compared to my VE table or AFR error table? I am keeping my lower cells in the timing table at 10 degrees and want to start ramping up to get to 14 degrees at full tilt but don't want to keep guessing at my timing tables as to which cells are getting selected.
thank you
do I use DCA (dynamic cylinder air) after I have added to my channels to make a graph? I am in the process of doing that but wondering what axis I should use?
What will the graph for dyn cyl air look like by chance? Any examples?
As far as scaling, I have started a new tune file that will be 50% scaled. Seems simple enough to do....just more data logging. Still want to know exactly where my timing is at and what my grams/cyl comes out to.
Started to drizzle in a few degrees here and there. Car is showing 80 lbs/min of air tonight, so that is roughly 800 crank HP! Off the map at this point so might be done with HP gains until I go 3 bar.
again, thank you for the help.
But I like only have the last row!
Also, just for reference, I am at about 1.16 g/cyl now at 6000 RPM and 205KPA. So I am back in control of the timing and dial the tune in with confidence. Will end up hitting the end of the table too like most but at lease I can run just over bar and still have timing numbers to play with.
The P59 will then get me over the 1,000 WHP goal...but that will take ID1300's, a new T56 and the whole winter to get this combo ready for spring.
Thanks again for the help
