e38/gen 4 gurus school me up
Old Sep 24, 2018 | 06:45 PM
truckdoug's Avatar
Default e38/gen 4 gurus school me up
so I'm getting asked more and more to look at e38 (and e67/e78/e92) swapped vehicles. I've had limited success with getting them to run right. For the last one I just put it on the MAF and it seems pretty good.
But, that's not gonna work for boosted applications.
How the hell does Virtual VE work?
How can I make an e38 run on straight SD?
What is Virtual Torque and what does changing it affect?
I have a guy with a C7 corvette who just wants some firmer shifts at part throttle now that he's got a stall in it.
Took a look at his shift tables and there's literally 50 tables!
any direction to a good tutorial for these later ECM's would be appreciated. They're starting to hit the wrecking yards so I oughta get into the learning curve.
Old Sep 25, 2018 | 08:53 AM
brandon6.0's Avatar
The virtual ve is definately a different breed. Ive never had good luck with it on the gen4 aps. I remember when blue cat had the first tool to tune it. Hptuners now has the tools integrated into the software.
I have always just used maf only and they seem to run pretty good. I havnt tuned a boosted gen4 yet either. Interested in what others have to say.
Old Sep 25, 2018 | 01:28 PM
truckdoug's Avatar
Are your swaps using the 6L80/90 the 8L90 and the new 10R90 ?
The sheer number of tables has me bummed. I'm scared to poke it with a stick in case it bites back!
Old Sep 25, 2018 | 02:00 PM
LSX Power Tuning's Avatar
We see more E38/T42 swaps than E38/6L80's mainly due to the size of the 6L80. E38 swaps are a differnt aninal to tune when you get into mix matches engine trans combo's. Everything needs to match also, TB, gas pedal, and OS in the tune along with the vin in ecm/tcm or you will have all kinds of headaches, new DI E92 swaps are even more challenging.
Old Sep 25, 2018 | 05:30 PM
truckdoug's Avatar
so with the t42 trans controller you can use a 4L80e?
Old Sep 25, 2018 | 10:43 PM
brandon6.0's Avatar
My tbss has a e38 ecu, not sure on which tcu. i swapped a 4l80e in it 2 yrs ago and it works great! I used a pcm of nc conversion harness and changed some things in the tune. I dont even think im using the front vss sensor as well.
I usually run 6l80e in the swap platforms with the e38. They are a big trans so they can be hard to fit some swaps. They are definately tricky to tune. Alot of tables compared to the older stuff. They are also funny about making mph match the rpm for the correct wot shift points. I hate to tuning them.
Old Sep 25, 2018 | 11:08 PM
Yes a T42 can run a 4l60, 4l65, 4l70 or 4l80.
Old Sep 26, 2018 | 01:39 AM
subeone's Avatar
E38 same tuning concept as 0411 man even the virtual ve
Old Sep 26, 2018 | 05:59 AM
cam's Avatar
cam
Fuel pedal is one thing an e38 is not married too, you can use any gen IV and newer fuel pedal that info is incorrect. For almost all swappers its much easier to use a 24x reluctor and run the older PCM imo
Old Sep 26, 2018 | 12:15 PM
turbolx's Avatar
If only there was some sort of training DVD that covered virtual VE.
To be fair, we made this a while ago when EFILive was the only tool that could natively calculate the VE coefficients. HPTuners now has a tool built in as well, so we may go back and create a new video using that tool, but in the menatime, the process is basically the same with either toolset.
Old Sep 26, 2018 | 02:12 PM
truckdoug's Avatar
Cesar are you tuning all those NNBS and newer trucks I see on your youtube channel with e38 computers on speed density?
Old Sep 26, 2018 | 02:25 PM
Jenson's Avatar
This;
And this are very helpful;
https://forum.hptuners.com/showthrea...Cat-VE-Program
Ive done a few LS2 GTO's in SD. I have looked at the new tool in HPT but I have yet to use it lol. Its harder to tune the 6l80 than the VVE. There are so many tables (most dont do anything) and there are very few reputable sources giving up the ghost on what to actually change. Ive got mine doing pretty good now but its still a work in progress
Old Sep 27, 2018 | 01:28 AM
subeone's Avatar
yea man all of em are SD it's super simple it's like 0411s I might do a vid for ya if you cant figure it out
Old Sep 27, 2018 | 09:41 AM
truckdoug's Avatar
do it please! you know I'm always pimping your channel out to my two hundred sixty five subscribers!
Old Sep 27, 2018 | 10:47 AM
Jenson's Avatar
Haha, I watched your vid on the 6l80 tuning subeone/cesar. Very helpful, but Ive used the bluecat trans thing on a few of my cars now and it just never seems to get it right for the shift. I go straight off a gear calculator app instead (and for all customer cars).
Old Sep 27, 2018 | 10:23 PM
subeone's Avatar
here you go, im no greg banish (turbolx) but it should be an okay guide for you
Old Sep 28, 2018 | 12:08 AM
truckdoug's Avatar
thanks cesar! I appreciate you making that.
I you really highlighted what I think the problem I've been having is.... shitty injector data from the snake eater 150's everybody is buying
it makes the estimated TQ values so far off from reality the transmission is impossible to tune (im using the blue cat tool)
Old Sep 28, 2018 | 09:13 AM
The best thing you can do if your tuning for money is tell people no when they have a setup that isnt right. If someone has knock off injectors, knock TB, or really awful combo we just politely decline to tune. It saves you money, time, and headaches in the end. Its crazy in the difference in tuning something with quality parts and built correctly vs knock off parts and miss-matched setups.
Old Sep 29, 2018 | 05:32 PM
truckdoug's Avatar
yes I'm learning that the hard way. but it is a good education.
Old Sep 29, 2018 | 10:32 PM
brandon6.0's Avatar
Or be straight up front with them about tuning it. Say hey u dont have quality injectors with data, ill tune it the best i can with what u have. Im not saying it will be perfect, but ill try my best. Maybe add an extra $100 to the tune bill for time spent 😀
