How to "Split" a 5v Signal
Reason, I have an holley EFI, and a Fast EZ TCU. Both need a TPS signal.
Right now, I have a splice in the line, but, this is introducing a lot of noise causing odd behavior such as... Holley EFI not "Learning" as much as it should, and erratic shifting / Lockup in the transmission.
For the EE majors here,
How can a 0-5v signal be effectively split, without introducing a lot of noise.
And, before somebody says it, Yes, I am well aware there are remote-mount TPS systems, and other solutions involving a second TPS. However- there is a simple method to accomplish splitting the signal, using electronical components. I just don't know it.
https://ls1tech.com/forums/automatic...ignal-dbw.html
https://ls1tech.com/forums/generatio...e-jumping.html
https://forums.holley.com/showthread...ectronic-trans
https://forums.holley.com/showthread...4139#post84139
https://forums.holley.com/showthread...-transmissions
https://forums.holley.com/showthread...ntroller/page2
None of those answer my question.
I would have thought the Holley could repeat a signal for one input to another output but haven't messed with one. Your. other option is a couple of the TPS sensors have shafts that can be made to pass through the sensor, just stack 2 of them one for each black box.
