Any tech 2 gurus in here?
Old Oct 21, 2018 | 07:57 PM
warriorpluto's Avatar
Default Any tech 2 gurus in here?
Im trying to program a 2008 avalanche window switch using the last version of tis2000/tech2win on my laptop. Ive programmed alot of modules with it but this windows switch ive never done before. Do i go to replace and program ecu or just reprogram ecu? If i go to reprogram ecu and go to program the window switch it says it cant communicate with it. Anyone else have this problem?
Old Oct 22, 2018 | 12:33 AM
LSX Power Tuning's Avatar
Do you have a CANDI module plugged into your tech2?
Old Oct 22, 2018 | 06:50 AM
No just a laptop. I don't have a physical tech2
Old Oct 22, 2018 | 08:21 AM
To flash 2008 and newer with a tech 2 you need a candi module so I would assume the virtual tech2 wont work. Since I have a tech2 I have only tried the virtual tech2 once for scanning something just to do it so I could easily be wrong.
Old Oct 22, 2018 | 08:51 PM
GMTECH4's Avatar
what interface are you using to program with? I have never been able to program with virtual tech 2. we always use gm sps programing
