VSS input requirements
I'm trying to setup VSS on a conversion to enable the cruise control. To do this, I need to know how many teeth there are on the shaft that the VSS reads from so that I can make up a trigger wheel to mount on the prop.
The second question is, do the automatic and manual setups in the P59 PCM expect to see a different number of pulses, i.e. Are there a different number of teeth on the output shaft of a manual vs an automatic vs a transfer box mounted vss?
40 on a 4L60E
17 on a T-56
If you are making a trigger wheel why not make it how you want it and adjust the calibration accordingly? Another option is running the VSS from the reluctor wheel on a drive hub from the ABS if your vehicle was previously equipped or had a option for it.
I don't have efi live or HP tuners so can't adjust the calibration. I had wondered about using the abs sensor, but it's a 60 tooth setup on a 285/75/16 tyre so without being able to alter the calibration, I run up against the same problem. I also don't know if splicing into the sensor would upset or weaken the readings the ABS ECU sees.
