mpvi2+wideband when?????
https://www.ftdichip.com/FTDrivers.htm
When shopping for a wideband, you need to read the installation instructions first for each model to determine where the data stream comes from in order to determine where to attach your cables which ultimately connect either to the MVPI PRO interface or to an open USB port on your laptop (if you choose the method explained in this thread). Or whether you need a gauge for not.
This thread explains how to use the MVPI2 interface in conjunction with a USB to serial cable adapter and db9 pin cable in order to datalog with the MVPI2 scanner while at the same time merge the data stream from the ODB II port with a separate data stream from your wideband. This means you don't have to wait for or buy an MVPI2 Pro wideband data logging interface.
If you choose to use the method explained in this thread, the HP Tuners MVPI scanning software merges the two data streams and presents the data to you thru the HP scanner program screens, charts, and graphs.
As for whether one can receive a wideband data stream from a narrow band sensor on your C5 via the PCM and OBD-II port, the short answer is no. In order to receive a wideband data stream for data logging purposes, you have to install a wideband sensor along with the wideband controller. Your C5 has narrow band sensors, so you need at least one wideband sensor along with a compatible controller.
This link below explains the differences between narrowband and wideband. Note, the latest Bosch sensor is now a Bosch LSU 4.9 sensor instead of the earlier 4.2. The two are not interchangeable. So when shopping for a wideband, make sure to get a wideband controller that is compatible with the 4.9 or delivers with a 4.9 sensor. For example, the AEM 30-4100 wideband controller cable for the 4.2 will not connect to the Bosch LSU 4.9 sensor. So for me, if i want to to use the 4.9 sensor, I need to upgrade to a later model or different mfg.
https://www.autometer.com/resources/...faq_view/id/13
The devil is in all of the details, there are no short answers.
hth
hth
i'm new to tuning and i'm going to have a friend try and teach me the basics of tuning.it sounds like if i plug the mpvi2 into the obd2 port and wire a serial cable to the mpvi2 then use a usb-serial adapter to plug into the laptop i can get a wideband graph on the scanner program without needing a aftermarket gauge and sensor?
As explained in a earlier post in this thread, the pathway below is how to get data from a wideband sensor into your laptop so the HP scanning and logging program can interpret and display the data so you can use it to tune your car.
Pathway wideband: Wideband sensor > controller/gauge> db 9 cable>USB to serial cable adapter>USB port on laptop > HP Scanning and logging program screens.
If on the other hand, all you want to do is scan and log your car with the HP Scanner and just read the narrowband data, then no, you don't need to purchase a wideband. The data that displays from the scanning software will be narrowband, not wideband.
Perhaps you should download the software and open the scanner and open the sample log and watch as it displays the short term and long term narrowband data stream (O2 narrow band sensors on your C5).
If you decide to purchase a wideband and install it in your C5, then you have two options if you want to be able to read the data that can be retrieved from the wideband sensor and controller.
1)You can buy the HP MVPI 2 Pro interface module and connect it your wideband and use it to datalog wideband data streams.
2) Or you can used the method explained in this thread that bypasses the MVPI2 interface module via a USB port on your laptop. Note that this method has far less functionality than the PRO module. However, sometimes less is better if all you need is wideband data.
HTH
https://ls1tech.com/forums/pcm-diagn...-question.html
HTH
so from the pic i would wire pin2 from the serial cable to the blue serial output on the gauge and pin5 from the cable goes to ground.would you connect the white 0-5v wire to anything?
https://www.aemelectronics.com/files...GO%20Gauge.pdf
I was using my ac pressure switch and trying to get the right offset so my actual afr was matching what hp tuners was logging. If you are trying to do that then you need to throw that **** in the bushes. The serial port deal rocks!
Edit, I think I found my answer. I didnt see the pic in this thread of the harness somebody made. So then those 2 leads that were cut just go to the wideband, the other into the laptop?
