Using pin 44 for reverse lights
Old Nov 3, 2018 | 10:29 PM
troymrtn's Avatar
Default Using pin 44 for reverse lights
I have a 99 ls1 in a 1990 RX7 with a 4L60E. I do not have the reverse light / neutral safety switch at the transmission. Is there a way to use pin 44 at the PCM which is for the reverse lock out solenoid control to control the reverse lights? Anyone try this?
Old Nov 4, 2018 | 11:22 AM
voda1's Avatar
Circuit logic described here: https://www.corvetteforum.com/forums...mely-hard.html
see post #17.
Old Nov 4, 2018 | 06:04 PM
troymrtn's Avatar
see post #17.
So it’s not possible. Thanks for the info.
