gm tech2 on craigslist
Old Nov 14, 2018 | 04:00 PM
poorboy's Avatar
Default gm tech2 on craigslist
hey i dont know much about the gm tech2. would it be useful in my toolbox or is it outdated. i only work on my own stuff and i only drive old junk. arguements welcome
Old Nov 14, 2018 | 04:15 PM
How old a junk do you mean?
Old Nov 14, 2018 | 04:28 PM
poorboy's Avatar
10+ yrs. My daily driver is a 94 fullsize blazer. I have an 86 chevy truck and an 04 denali motor i wanted to throw together this winter and im struggling to decide how im going to make that happen also. lol
Old Nov 14, 2018 | 08:26 PM
LSX Power Tuning's Avatar
How much the tech 2 and are you sure its real vs a chinese clone? There are no more updates for tech 2 so if it has the last update then its good to go.
Old Nov 15, 2018 | 09:40 AM
poorboy's Avatar
the guy is asking 800 for it and it comes with all different cords/plugs whatever and some candi device?? i dont really see myself affording one anytime soon. what is the latest tech2 software and how does one decipher if its a clone from genuine? is there any sort of alternative diagnostic tool thats out there that can do all the stuff gm stuff? i found a video from summit that explains the hp tuners will change parameters for engine management which is what i will need to do to get my swap done.
there has to be aftermarkets competitive to snap-on or mac but what cant they do? sorry for asking retarded questions
Old Nov 15, 2018 | 01:21 PM
To make changes you need tuning software like hp tuners. A tech2 will flash stock oem files that you pay to get. It wont allow you to make changes in the tune.
Old Nov 15, 2018 | 02:53 PM
poorboy's Avatar
can tech2 disable vats?
Old Nov 15, 2018 | 02:56 PM
poorboy's Avatar
like say i want to do a swap keeping everything OE except for the vats, im sure there is a thread on here on topic but i havent found it yet
 Michael S. Palmer
Old Nov 15, 2018 | 04:23 PM
no it cant
Old Nov 15, 2018 | 04:32 PM
poorboy's Avatar
good 2 know thank you.
Old Nov 15, 2018 | 04:38 PM
poorboy's Avatar
hey say i wanna diagnostic scanner to work on domestic and asian vehicles. what should i look for? say i have a $300 budget
Old Nov 17, 2018 | 01:47 AM
TPIZ92's Avatar
Vxdiag nano...does everything the tech2 can.
Old Nov 23, 2018 | 08:53 PM
Gary Maurizi's Avatar
Hey TPIZ can you tell me, will the vxdiag nano work for my 1999 camaro z28 / ls1? I just asked the seller on amazon and they said NO, yet the amazon listing for the product says it's compatible with GM class 2 network and UART? and I see people on corvette forums using it for their 1999 corvettes... I don't understand why he says it wont work if its the same as a handheld tech 2?
I need the cheapest possible solution to scan and troubleshoot all of the modules on my car, and reflash with stock files (I don't necessarily need to tune anything though this would be a cool option to have) but I don't want to spend over $250 including any licenses and the vxdiag nano pro seems to come with cracked oem software already?... I don't want to have to buy a license everytime I want to scan another car either, as I want to use it to shop for used cars someday.
So far from my research my best options for ALL module diagnostics seem to be the bluedriver(seems to scan ABS, SRS, trans ecm, pcm but no flashing but i don't think it can do 2 way testing?), launch Creader seems to scan the same 5 modules but no flashing and I don't think 2 way testing?, there are some outdated options from drewtech on ebay like the mongoose for cheap but it looks like you have to buy legit copies or find cracked copies of tech2win or gds to use it? Theres a bluetooth dongle one called vpecker XTUNER from autool that uses a bluetooth dongle like the bluedriver but im not sure what modules it can scan (i think the same 5 modules) but this one seems to have 2 way testing to command windows/doors/etc... then theres' the option of a chinese clone tech 2 handheld? Ideally I want something that can work well for my camaro but also work to scan a toyota prius in the future, kind of stuck here as its all alot to take in and im new to it all? Maybe I should just get a clone tech 2 handheld and another cable for toyota tech stream later...
PS. Apologies for hijacking and reviving an older thread...
Old Dec 1, 2018 | 01:37 AM
TPIZ92's Avatar
It will work. And I have even flashed my vcm with it using ac delco sp online software. I have scanned the vcm, airbag, srs and ipc codes with mine. If uses emulated tech2 software but it can also emulate the mdi and mdi2 bit I havent tried that. Hope this helps!
