How much fuel will I need
i went with a 450 in the tank, thought it should be up to the task but thought I'd ask.
is there a calc to figure out gph needs?
http://www.mopacautosupply.com/Fuel-...tors-s/356.htm
I thought I did the right math a while ago but after I saw your recent post about Pearl and using 2 450's in the tank I thought I better re-check.
and while i think 2 450's are fine for a dyno hit, I dont think they would reliably fuel 1000 hp vehicle down a 1/4, at least in the deadheaded configuration I had them. I had plans to rearrange the fuel rails configuration and I think it would have been good to 900 wheel at the track with the regulator after the rails.
one 450 in the tank will do 650 crank on gasoline and methanol, sloppy has proven that combo is dead reliable
