Camaro Not running right
Old Nov 29, 2018 | 10:18 PM
dnbenjam's Avatar
Default Camaro Not running right
I am wondering where my problem may be on my 2010 V6 Camaro. I have changed everything under the sun to prevent the misfires but the high pressure fuel pump, timing change, and fuel injectors. The codes that are thrown are Random multiple misfires, Misfires on cylinders 2,4, and 6, and low fuel pressure. I have put a new fuel pump on it, but the car is still reading that the pressure is low. Is the pressure regulated by the PCM or the high pressure pump? Thanks in advance for your help.
Old Nov 29, 2018 | 10:23 PM
As far as the misfires, check all your grounds on that side (2,4,6) of the engine.
Old Nov 30, 2018 | 11:54 AM
Drj8787's Avatar
Are you able to scan the fuel trims? Could be a bad o2 sensor on that bank
Old Dec 4, 2018 | 01:26 PM
dnbenjam's Avatar
How would I go about checking the grounds? At the electrical terminals connected to the injectors?
Old Dec 4, 2018 | 01:27 PM
dnbenjam's Avatar
I am fairly new to this, but I have been able to do all of the work myself. Still getting used to the car vocabulary. What do you mean by fuel trims?
Old Dec 4, 2018 | 01:29 PM
That, and the other end where they ground to the engine, chassis, or body
Old Dec 4, 2018 | 02:00 PM
dnbenjam's Avatar
Thanks. I will look into that this afternoon. Here is a list of things I have changed so far:
Oil
Spark Plugs (twice)
Ignition Coils
Intake Camshaft sensors
Crankshaft Sensor
Both Fuel Pressure Sensors
Vent Valve Solenoid by the tank
Solenoid Purge Valve under the hood
Fuel Cap
Low Pressure Fuel Pump in the tank
Old Dec 4, 2018 | 06:57 PM
Drj8787's Avatar
Fuel trim is how much fuel the pcm is adding or subtracting from engine. The o2 sensors is what controls this. So if the engine/tune is set to produce an air fuel ratio 13.5 and the sensor is reading 14.0 it starts adding fuel until it is correct or visversa if it’s set to be 13.5 and it’s reading 13 it start pulling fuel out of the tine until it’s corrected. If one or both sensors aren’t working as they should it can cause some majors drivability issues and potentially damage to the engine if left un-corrected
Old Dec 4, 2018 | 07:22 PM
s30.hybrid's Avatar
Since it’s the entire bank this should be your starting point to troubleshooting.
Old Dec 5, 2018 | 08:03 PM
dnbenjam's Avatar
Copy. I was thinking about the O2 sensors as well, but I am to the point where I am tired of throwing parts at it. I took it to the dealership and they gave me this long list of things they wanted to do that came out to about 5k. They wouldn't tell me what the problem was.
Old Dec 5, 2018 | 08:07 PM
dnbenjam's Avatar
Ok. Thanks. When I took the fuel rails off to check them, I put everything back on and the entire bank is still showing misfires. I am going to look into the O2 sensor next. Thanks for the information.
Old Dec 5, 2018 | 08:43 PM
s30.hybrid's Avatar
5 Jeeez and they won’t even tell you what’s wrong with it? Holy crap!
Since it’s a V6 you can swap the O2 sensors left to right and see if the misfires follow the sensor to the 1/3/5 bank. No need to throw anymore parts at it unless you prove the sensor needs to be replaced.
Old Dec 5, 2018 | 09:28 PM
Toes's Avatar
i Would guess the 246 side has the coil pack connector unplugged. Or a ground broke off. Having one side of the engine misfiring is suspect. Do you know if you have spark on that side? Cold exhaust manifold?
