Supercharged LT1 tuning options?
I have read that you can tune one of these LT1s with TunerPro, but to flash the PCM you must have a seperate program like TunerCats... Can anyone confirm this?
Is there a 2 bar or 3 bar speed density setup for something like this????? I also have wondered about repinning the harness to use a 411 PCM since I am quite familiar with making that one happy with boost.... Is that an option???
tunercats has the definition and everything you need. 2 bar and all that I dont know. Haven't messed with it. I did a turbo impala once but I cant quite remember any particular details from it, it was awhile ago.
and @ElQueFør hptuners can handle it no problem. Tunerpro? I assume you are skilled in winols, hex, or rom editing? That is a very technical program imho.
subeone,
HPTuners can do that??? But how it's OBD1, I thought HPT was OBD2 only....
I actually had my first EFI tuning experiences on TunerPro using it on mainly TBI small blocks in the past. It is a pretty complex program layout compared to HPTuners for sure..... You just load a tune file with HPT and start editing. With TunerPro you have to load the tune file AND the correct XDF (code mask) to edit the tune file. Also, gotta load up the correct ADX (datastream definition) when viewing logs.... I have a little bit of experience in hex. There is electric fan code that I have patched into several '7427 TBI PCMs and you have to enter the code patch in a hex editor of some sort.... I like HXD for a free hex editor.....
