WTF is up with my SES light???
Old Jul 10, 2004 | 12:47 AM
BriancWS6's Avatar
Default WTF is up with my SES light???
Alright, two weeks ago my SES light came on and I had it scanned. Codes 1133 and 1153 were what it was. I was told that was the front oxygen sensors. I had the other ones that were behind the converters when I had them on, so I put the right rear on the right front and same for the left side. I unhooked the battery and after 20 miles or less the lightcame back on. So I unhooked the battery this Mon and didn't hook it back up untill fri afternoon. About 10 miles or less the POS light is back on. What is going on? Did I not fix it or do I have to actually have the pcm "cleared" with a scanner? What do I need to do to make this stop? Also are those codes hurting my performance in any way? Please help.
Old Jul 10, 2004 | 02:37 PM
BriancWS6's Avatar
Come on, all these people on here and noone can help me? This is driving me insane!!!
Old Jul 10, 2004 | 04:05 PM
whitez71's Avatar
Try this link
https://ls1tech.com/forums/ls1-domestic-forums/t-44282
Old Jul 11, 2004 | 12:45 PM
BriancWS6's Avatar
Thanks for the link. I did use some leaded fuel on the night the SES came on, but I had done it twice before last year with out a problem. I know that lead screws up the sensors, but I didn't understand why when I put the other two O2s in that the light came back on again. I have run approxiamately 20 gallons of 93 fuel through the car since the nite I had the 2.5 gallons of leaded 110. I still get an occasional whiff of the racing fuel and it's been a while since it was in there. Did the remaining traces of lead mess up the other O2s that fast? Do I need to wait a while to get all the leaded fuel out of the system before trying to put in new O2s? Is there anyway to clean them? Thanks.
Old Jul 12, 2004 | 11:51 PM
CODE4LS1's Avatar
you probably shhouldnt have used the rear 02's in the pre-cat holes. The computer relies on the front 02's for air/fuel, and the rears are just for emissions. That's my guess anyway.
Old Jul 13, 2004 | 01:39 AM
BriancWS6's Avatar
Supposedly the front and rear O2's are the same, as long as you go right front to right rear and vice versa. I was told that they are different pn's from pass to driver side. Who know's, the POS light is still on and I don't know what to do.
Old Jul 13, 2004 | 10:40 AM
CODE4LS1's Avatar
I would bet money on it as a matter of fact. From what the dealer told me when I was having trouble with my 02's, is that the rear (post cat 02's) dont do a whole lot. It's the pre-cat 02's that tell the computer how rich/lean, etc. If I were you I would switch them back
Old Jul 13, 2004 | 10:55 AM
deezel's Avatar
The front/rear and left/right O2 sensors are all the same. They have different part numbers because the wiring harnesses are different connectors and/or different lengths.
If you didn't run race fuel with these sensors, they shouldn't be hurt by any "lead residue" that remains. Are you getting the same 2 codes as before you changed the sensors (insufficient switching on both front O2s)?
