After-Throttle low Idle issue
Having looked at your tune another change I'd make is in the idle-airflow screen, all your min's in the adaptive idle airflow are -3. I would personally set those to -0.5 to avoid it saving a persistent -3 g/sec and undershooting on return to idle.
The best test is to sit in your garage, stab the throttle without the car moving. if it undershoots when it comes back down, you need more proportional low airflow. Car not moving keeps the cracker out of the equation. You can crank the cracker way up to avoid it while moving, but it's a bandaid
1. you are persistently lean. It looks like your O2 sensors are unplugged, because they just sit at 440 mV. your wideband is showing 16:1 up to 18:1 in places. If you had tuned the car previously with the min fuel mg at stock, then that setting was keeping you from leaning out the mixture. Now that it's lower, you are lean. Getting some fuel in there will help.
2. You went a little too high on your proportional airflow low tables. Try these values: 0 0 0 0 0.03125 0.328125 1.203125 1.6015625 2 2.3984375 2.796875 3.203125. Hold 3.2 out to the end of the table.
3. Under Engine - idle - RPM, set the "Update RPM Err Max" setting to 80 rpm.
4. I noticed in the log that your spark is not going into adaptive idle. It was just holding at 20 degrees. Had you commanded the spark to 20?
5. Your IAC is holding right at 30-50 counts at warm idle. Your idle trims are persistently high. Two possibilities, but would need to see dynamic air on the log to know for sure which is the case. You may have pasted your IAC values too far to the right.
6. Base Airflow - Set your 100C column to 14.3 g/s and interpolate back to your 40 C column.
7. Engine - idle - Airflow. Set your max InGear / AC Off field to 5.00 g/s
8. Engine - Spark - Afvance. Set your overspeed spark table to mirror your underspeed table. Where there is a "10" in the underspeed table, put a "-10" in the overspeed table for example.
The mystery for me is why your spark was holding a steady 20 at idle. If it was doing what it should do, it would likely correct 80% of the remaining surge.
