Whats a good lap top for tunning
Good to hear. Which model number?
TIP: Best battery runtime will be from a 9 cell battery pack. Some models don't come with a 9 cell - usually 6, some even a 3. If you plan to use it a lot in your car, I would opt for a 9 cell - unless it's a t450. The t450 has an internal battery as well.
SSD's don't require periodic defrag. Turn it off.
Windows>run>msconfig>Boot tab. Turn the timeout down to 2-3 seconds. That will speed up boot time.
Good luck
Good luck
do you need a cd rom drive to run hp tuners pro ? or does it come on a flash drive ?
