Poor Fuel Mileage
Not sure what is causing the worse fuel mileage. I did have a u-joint go bad, but i fixed it and still getting bad mileage. Any ideas or suggestions on something to log to see if it is the cause?
My next idea was to possibly tune out the MAF and O2's for SD tune, and see if that helps any.
Actually I did get new tires. I went to a Nexen 10 ply tire cause it was cheaper then the old Goodyear Wranglers. (had too many sidewall punctures with the wranglers).
I track my fuel mileage every tank, and graphed the mileage over the past few years. The drop didn't suddenly occur when the tires were put on. But slowly decreased around the time of the new tires. So i wasn't convinced the heavier tires caused 20% fuel mileage drop.
I might have to swap wheels and tires with my dads pickup to see if there is a change.
Since it sounds like you have HPT or EFI, have you looked/logged the O2's to see how they are swinging?
I have air tires up and down. put them to 50psi to see if it would help to no avail.
Also this time of year we are on the winter blend fuel, typically worse MPG from that, which may be compounding some other problem you have.
How are your brakes? Maybe one of them sticking a bit?
however if the maf is reading poorly and it has new o2's you would think you would see high correction on the LTFT, correct? I'd assume the LTFT have final say in how the engine runs?
Remind me, is a positive number on LTFT's mean it is lean and adding fuel?
Also if the fuel trims were high, doesn't that mean the o2's were doing their job. Essentially it is running stoich, its just that the O2's are relied upon more to make it run at 14.7 afr instead of the maf?
BTW, I'm using efiLive. I was thinking to test if the maf is the cause I could simply make the changes to the existing tune to turn the maf off. If fuel mileage increase then I know the maf was at fault. will this work?
I would address the reason why it's using more fuel before making actual changes. LSX Power Tuning made a good point. Make sure the MAF is doing its job before counting it out.
I wanted to turn off the maf in my tune, simply to see if it would run better or worse. I just wasn't sure if I needed a COS to do so, or if i can make the changes in the current OS it is running. try it out, and if it seems to run better and get better fuel mileage then I can replace the MAF.
I made a special brush to clean the MAF sensor elements, it is shaped like a "J" hook. Another thing to think about is cam timing. Has the timing chain retarded the cam in the last few years?
Good luck.
