Android compatible
Old Mar 19, 2019 | 10:17 AM
rodwood's Avatar
Default Android compatible
Hello all,
Could someone help IM new to the LS tech and currently in the middle of doing a EROD swap in an 86 C 10, when I start for the first time " if it goes as hoped" my gauges will not be connected just yet, IM looking for a simple to use blue tooth that will give engine stats Oil pressure water temp RPM Voltage ECT. that will also give and clear MIL codes once adjustments are made. can anyone point me in the right direction.
Thanks a ton,
rodwood
Old Mar 19, 2019 | 05:22 PM
DFORESI's Avatar
The Torque App for Android is really good, it will work with pretty much any bluetooth dongle, although if you want something that can send data at a quick rate, stay away from elm327 based dongles. OBD Link LX would be a good place to start.
