PCM LQ9 swap question
My question is, can I use the pcm, harness and gas pedal that came from the LM7 on the LQ9?? Checked the service number on the PCM 12589463.
If the 6.0 is a Gen4 you can still use it but it needs a 58x to 24x converter box.
The gen3 engine has plastic round fuel rails, rear CAM sensor, valley Knock sensors and 75mm TB.
Gen4 has square stainless fuel rails, 90mm TB, different intake, side knock sensors and front CAM sensor.
