Alternative Tach pick-up for shift light???
Old Apr 22, 2019 | 11:18 AM
jtl12419's Avatar
Default Alternative Tach pick-up for shift light???
Hi,
I want to install a shift light but the location of my harness into the PCM is physically very hard to reach for safely soldering a splice. Is there an alternative location to get the same tach signal, like in the engine compartment to have better physical access for splicing a wire?
Mazda Rx7 LS engine, PCM in pass footwell, full roll cage. Hard to reach and I risk damaging the harness wires by manipulating, stripping, and attempting to solder, around the rollcage.
Thanks in advance.
Old Apr 22, 2019 | 02:36 PM
Drj8787's Avatar
Do you have a tach in the car at all?
Old Apr 22, 2019 | 03:49 PM
jtl12419's Avatar
Yes, but likely just as hard to reach, under the dash on drivers side.
Tach works fine but would like to have a shift indicator at eye level.
Old Apr 28, 2019 | 06:30 AM
jtl12419's Avatar
used these for tool-less tapping into the harness:
Posi-tap wire connector
