need help with MAF 85mm or card style?
second image the MAF is mounted to block off plate which looks nice and clean but I would need to extend the MAF harness
any suggestions where to get clamps and boots and 4" tube thats reasonably priced appreciated also
"Saxon makes the honeycombs and Spectre makes the 4" tube among others."
lotta thread to read, actually did browse through before posting this thread and it really didn't answer my question
Spider knows much more about the scaling side on this than many on here do, and is the resident expert on this topic. The type of MAF IMO isn't the real issue. The PCM is.
2 I know, I'm only looking around 400HP. The reason I was considering is adding the MAF to a similar air intake is more complicated and isn't a clean looking install IMO
And yeah, I guess I misunderstood his question. Tune is always required when switching MAF sensors, be it location, type, or brand... Yeah... Pretty important to calibrate it. 400 hp doesn't even need scaling, or shouldn't at least.
can't I have both? I don't want this to be done half arce!! hence me looking around to see what my options are the Card maf seems so much simpler to install. I plan on tuning after its up and driving
ddnspider- I get it I guess I am wondering if it would run and how poorly or would be be tolerable until tuned
I was just saying it will need a tune, because the MAF is so important. In your case it may learn itself out enough to run, hard to say, but just expect to need a tune when playing with airflow and the primary sensor for fueling calculations. I would definitely not run the car hard at all until tuned for the change. That is extremely risky to the engine to get it anywhere near Power Enrichment (just think spirited driving) since that part of the tune will not “learn” at all, and could potentially cause a catastrophic failure. I would predict this setup to put you very much on the lean side since it’s vastly better than the stock airflow.
So really, you can run whichever MAF you believe looks better and fits your new design better, since either way it needs a tune due to the increased airflow and sensor location.
