4l60e TCC not connected - does work when connected
Please, just leave the wiring alone. Do NOT install a switch. You can easily go into the settings with HP Tuners and set up the T/C so that it does not lock up until what ever speed you choose, and in whatever gears you choose. For example-you could set it up in the tune to ONLY lock up at speeds of 60MPH or greater, and only in 4th gear. Then, you can cruise in town all you like but the computer will never lock up the T/C until speeds of 60 or more, and then ONLY when in 4th gear. If the trans kicks down into 3rd, or 2nd, and your speeds are in excess of 60 it still will not lock the T/C until the trans is in 4th.......
