still getting knock sensor codes after replacement
Old Jul 31, 2019 | 01:08 PM
Trevor57's Avatar
Default still getting knock sensor codes after replacement
2003 5.3 all stock with 7875 turbo, and 80lb injectors. I got codes for both knock sensors, and replaced both sensors with oem, along with the harness. Upon replacement the codes show back up immediately. clear them, and they come right back. I have tested the sensors all the way up to the pcm, and they test as they should. I am getting no other codes. I am not sure if it is related, but the car seems to idle a little rough, and at about 800 rpm.
Old Jul 31, 2019 | 05:01 PM
LilJayV10's Avatar
what codes are you getting?
Old Jul 31, 2019 | 05:15 PM
Trevor57's Avatar
p0327 code. I am using the torque app, and I am getting knock counts. I don't really know how to interpret the info though. I did one wot pull and the count was at 150.
Old Jul 31, 2019 | 11:10 PM
LilJayV10's Avatar
Is this a new problem or have you been driving it for a while with no issue?
Old Aug 1, 2019 | 12:59 PM
aruss99's Avatar
Have you tried desensitizing the knock sensors after doing the turbo? Is your downpipe or any piping close to the frame?
Old Aug 1, 2019 | 08:24 PM
LilJayV10's Avatar
Read the thread. If they come back immediately there are other issues....
Old Aug 4, 2019 | 10:38 PM
warriorpluto's Avatar
Did you torque them right? I think it's only 19lbs. If you over torque them then they will set a code
