Crank Sensor voltage drop test help
These are the readings for Key On Engine Off
Here are the results for Key On Engine Running
You are down a rabbit hole.. You might not need to be down that rabbit hole at all. NO ONE wants to join in your rabbit hole without understanding first-why you are in that rabbit hole. Does that make any sense?
I have NO IDEA what you are trying to accomplish therefor I'm not sure what I can do to help you.
You are asking about which wire at the PCM is the power supply for your CKP.. lt1swap.com
Connector Pin
Blue 12 CKP sensor signal
Blue 21 CKP sensor ground (-)
I "believe" that the 12V power supply for the CKP sensor comes from the fuse/load box. If your CKP used a 5V+ reference signal, it would get that signal from the PCM. Since it uses 12V+, it is likely powered from the fuse box, like the O2 sensor heaters, MAF sensor, etc;
Again, why are you checking all of this stuff? If you are having a problem-tell us what the problem is and I'm sure someone here has had experience with it.
are there any other issues with the vehicle other than the code? if so please explain
do u have any access at all to repair information to diagnose the code? if not please provide me with year make model and I can possibly send it to you
also u cant effectively do a voltage drop test with a multimeter by itself because u are not simulating a load your just measuring voltage. 12 volts can conduct thru one strand of copper with no load or even a broken wire that's broken inside the jacket and is touching 12 volts can conduct as well. 12 volts can even conduct through your body as very small loads. but when u load the circuit that's when u find out what kind of voltage drop u have.
so do this take a test light THAT IS NOT AN LED connect it to a known good ground AKA battery negative insert this into the 12v+ terminal and while doing that measure your voltage on that terminal while the bulb is illuminated if it even illuminates.
now reverse this and test the ground side while putting your test light clamp and multimeter positive lead on the positive battery terminal
post those results and don't assume people don't wanna help.
is the pcm tuned?
because on a cold crank its running strictly off the VE map until it comes up to temp and the fuel trims start working...........study up on open and closed loop fueling to get a better understanding of this
when its running in VE mode it could be rich/lean or whatever and run halfway decent at idle. now when it starts correcting the VE table may be so far off that the truck is reaching the limits of what it can correctly adapt to fast enough to have stable fueling. so the erratic crank signal could just be because the engine is stumbling so bad the pcm comprehends this as a bad crank signal.
