PCM problem.
I never recommend the use of starting fluid / ether as a crutch to chronically get a motor running - it washes oil from the cylinder walls. But it is useful as a diagnostic tool once or twice. Spray some "explosion in a can" starting fluid ether past a fully opened throttle and attempt to start the engine.
Rick
Rick
I believe your issue is you cleared a failsafe in the older gm cars that when it lost the key signal from the little chip in the key that it stopped looking for it. ill get calls all the time never had a problem cranking it till the battery died. since the vehicle isn't running and it never receives the key resistance then it goes into security mode. if so go to your local car audio store ask them if the have a gm vats specific pack of resistors and solder it in place of the security wires.
OPTION 1 ... Under the dash VATS bypass. I had this in my car for 8 years.. Then it started having the issues again. 8 years though, not bad. I made these first 2 vids since NO ONE had ANY video tutorials at the time ..in the hopes that would help out others.
1.) PREP
2.) END RESULT
OPTION 2 ...VATS Passkey 10 minute reset procedure .... This will work if you're stuck somewhere and you just need to get it going. BUT It'll come back on the next time you try starting the car so... don't stop for fuel on your way home after doing this. Ask me how I know. I did the bypass under my dash after needing to do this a handful of times.
OPTION 3 ... And by far the BEST option, tune it out. I used HP Tuners since I have an MPVI2 now. Make sure that you do a "Write Entire" because if you do a "Write Calibration", I'll just come back. But your buddy will need to license your pcm to get in there and do it so it's gonna cost $100 for the 2 credits to do it.
