The Cam Isn't even THAT big
With a heavy clutch and flywheel you can get away with increased base spark and less adaptive. When you cut moi, you need the more aggressive adaptive spark.
By that same token, tables made for a lightweight combo might not work as well on a heavy package, because they may not correct enough.
My logic is basically this: Idle typically consumes approx 10 g/sec at 1000 rpm idle. So once I get to 100 rpm error, the car should need approx 1 g/sec. So I use 0.8 g/sec per 100 rpm error, except in the dead band. The other 0.2 g/sec I put in the integral table. Those are both in the rpm low areas. In the RPM high areas, I run something between 10% and 25% of factory, so it pulls air out very slowly.
This was how I was able to get it to settle down with throttle stabs in the garage, car not moving. No cracker when the car isn't moving.
I have also found that these settings work on heavy (stock or worse) flywheels also. The larger MOI makes the engine so much less responsive to the commanded changes that the ECU has plenty of time to react. When the clutch is light, it's almost like the engine reacts faster than the IAC motor.
The other thing I do is zero out the derivative from 0 to 0.05. An overactive derivative can take a stable idle and make it start oscillating all on its own. it helps keep the IAC motor from wandering around in response to minor cam surge.
But after some posts in the RPS clutch thread and a couple messages with Darth_V8R I figured that I might have been barking up the wrong tree.. So last week I zero'd out the cracker and follower tables and started over with the assumption that this problem stems from having a lighter clutch, and should be tackled primarily with PID tuning... And it's about 95% fixed again.
I'm about to start combining some airflow tweaks with the PID tweaks to see if that makes it 100%.
I can't help but wonder if the OP also did something to reduce the MOI of whatever is attached to his crankshaft, and how much that contributes to his car's return-to-idle problem.
It also occurred to me (embarrassingly late...) that the the cam really is a big factor in my return-to-idle problem. It's not entirely the clutch because the clutch was installed a few months before the cam, without tuning, and it still drove fine. The stock tune can cope with the light clutch alone, driveability just turned to crap when the cam went in. But retuning the PID tables for a lighter clutch makes perfect sense, and it's definitely a pre-requisite for getting the combo to work right.
You can always add more correction to get it to fall faster. Hanging it a bit can help you work out settling speed. Then keep increasing until it starts to undershoot.
In my own car I have 1/10 the proportional over speed air as under speed. Maybe not an exact tenth but a very high ratio difference. I want lots of supporting air low and very little correction high.
Derivative air, I would zero out until .05. Then use 2 for the rest of it. That will help stabilize the iac when you are close to idle speed but still be very reactive when large transitions occur.
