Bin and XDF Repository
I have created an unofficial fork of the Repo to learn how to work with GitHub. I will not link the repo here but it can be found under my same username. I have structured things quite differently and I'm happy to discuss. As of right now only some P59 Bins have been processed.
Issues are open on my repo if one prefers to discuss there.
Paul
I've read that domestic U.S. production Pontiac GTO engines had a Lean Cruise capability - model year 2004 . . . I think???? Not sure why the EPA let that capability through their emissions controls but you might look for a BIN from a GTO if you need one.
Rick
Paul
If you know were to look for it, you could enable it on a stock file and read it back out to get the BIN with it enabled.
I don't currently have anything to read out bin files.
Full credit, other then possibly a handful of files all BINs and XDFs were from BoredTrucks repo. Metacard info is from PCMBinBuilder and .gov vin lookup.
https://github.com/Snoman002/Engine-...Ilive-TunerCat
Rick
Paul
I recently volunteered to get a bin and XDF repository set up for the LS based engines that use the P01/P59 PCM. At this point in time I've gotten the basic structure down and am looking to populate and test my organization structure.
The goal of it is to get the newbies to OEM tuning a good start with one place to get all the files they need and as such it has a very basic structure that anyone who's googled LS tuning would be able to use. This complicates things the more files there are so I'm looking for more files to stretch this structure to the breaking point so I can further improve upon the structure. I hope to make it public either this week or sometime in January, but will be internally improving upon it until then.
If you have any stock bins that you wouldn't mind sharing please share them with me by sending them to boredtruckowner@gmail.
Also I'm looking for non-stock bins, so if you have any of those that you wouldn't mind sharing send them my way with a list of supporting mods, these are intended to be used as references only so someone who did a cam swap would be able to get up and running but would still need to tune etc.
The other thing I'm looking for is basically beginners mistakes and to dispell some of the misinformation that's out there, this isn't a top priority right now but something I'd like to get together. Basically condensing the stickies from around the web into one place so that someone new to the OEM world can get a better understanding of how it all works.
Paul
Give me a shout please.
Operating Systems · LegacyNsfw/PcmHacks Wiki · GitHub
Been a good while, due to some unforeseen circumstances I had to step back from the repo, we had major issues with work and up until recently I was working insane hours, only got to see the sunlight during my lunch break kind of hours.
Anyway, I will be picking up where I left off in growing the repo, a lot has changed since I have disappeared so I will spend the next few days informing myself before I get back to work. My main priority will be growing the wiki, there was a lot of information I was sitting on before I left that I can push to the wiki, but it will need fact-checking before I publish it. I've learned a thing or two about GitHub so I will also work on improving the structure a bit more, I've received some helpful feedback and will work on applying that as well.
If any of the owners of the other repos that have popped up would like to reach out and merge efforts, I am all ears.
Here's my current priority list and this will be revised as time goes on, but I'm also open to suggestions from anyone.
- OBDLink Compatible Firmware Note
- Expand Troubleshooting Help, I have a couple of sabotaged PCMs that I can recover and document
- Tuning Help, This is something I sat on for a while, I have a number of skeleton guides on what parameters need to be changed for certain mods, for example, it's super tricky to find a good video that explains what tables need to be revised with a stage two cam, and what some good starting numbers are.
- Walkthroughs, Since the beginning there has been a very limited number of good resources that explain what each feature does and when they are correct to use
My apologies to everyone for my abrupt disappearance.
Paul
Paul
Pretty much everything you've outlined has been discussed in great detail(firmware versions for example). Several members of the group have been doing volunteer work for helping people get setup with Tuner Pro and explaining the basics of how to use Tuner Pro. I also have a number of professional tuners in the group that chime in from time to time answering questions that can be hard to find details on online.
There would defiantly be interest in walk though video or even a written guide for things like headers, Airbox removal, Cam tuning etc.
Due to the number of users I was seeing with Ls Droid I didn't really have any other option other then to create a Facebook group and it's worked out very well for the most part. While it's not a good way to retain information in the same way a forum does it does; it does work well for getting answers quickly in most cases.
I am in the group and was gonna PM you to see if you were alright with me borrowing some of the more prevalent people in the group for some information if they are willing, specifically on the PCM recovery portions as those are what trip most people up. My ideas for the tuning and walkthrough sections are written guides with pictures of what needs to be done as those can be the easiest to follow when they are written right. As for the tuning part, that's where I am most comfortable doing write-ups, when I first began I didn't understand what each table did or the logic behind it but as time progressed I figured I was able to put two and two together and tune it just like any other platform.
One of the things I'm doing differently with Ls Droid for Windows(since displaying this is so much easier) is adding in as much information as possible and this includes written guides and embedded links for video's.
As for PCM Recovery......I have a special place for something like that if someone was to do a quality writeup with detailed pictures. I attempted to do it in Android but it was nearly impossible to display the information while trying to still interact with the apps UI. The way I've built Ls Droid for Windows I can removes the need to interact with the UI where the program starts a constant loop polling for frames from the databus, when it reads a frame that it knows what do to with it will lock onto the response and attempt to start the flash routine. If the flash routine fails or is reject it's able to jump right back to polling for frames again. I've had Dustin from the Ls Droid group do a bunch of testing for me with a BDM since I no longer have one that works on these computers where specific parts of the flash chip are erased or corrupted intentionally to make sure the programs able to deal with this type of thing in virtually any scenario.
I'm not familiar with the structure of XDFs, but is it possible to have two identical tables in different categories?
One of the things I would like to do is create new categories with all the parameters needed to tune something. For example, a category called cam tuning would have the necessary table for tuning idle and such, that way someone new to tuning can pull open the guide, have TunerPro open, and use the guide to go through each of the steps without having to pause and look for tables.
Also, maybe someone can correct me if I'm wrong, but I believe this is the first TunerPro cam tuning guide, the biggest flaw I see in the opensource LS tuning community is consistency, the XDFs are all different, there are no clear guides on what does what, what to change, or how to do it. One thing I want to try and do is to standardize a naming convention and structure in the XDFs for the P01 and P59, that way the guides would apply to both more or less. The XDF made by DzidaV8 already has everything logically structured, and the comments are helpful in understanding the parameters. I think that style of structure is the easiest to understand and find what you are looking for, the only other structure I see working is one similar to HPTuners so those tuning guides would also apply to the us.
The only way this would work is if the community adopts it, so thoughts or comments on the above?
Lastly, I am looking for one or two tuners who would be willing to read through the guides and fact check it, make recommendations, etc. If anyone is interested, please PM me and we will work things out.
Paul
