Not going into Power Enrichment (PE) Mode
My friend has a supercharged LS2 I just swapped into his 1972 Camaro. It came out of his 2006 GTO, which had been professionally tuned. So we yanked that PCM from the GTO and used it for the swap.
After the install, we drove around and I logged it to make sure everything was OK. Whenever he would slightly get on it though, it would pop/backfire.. and it turns out it was not going into PE mode, so was going lean in boost..very scary.. commanded lambda would always stay at 1.00
I didn't mess with the tune, but I have attached it, wondering if anyone can see what's the deal. It never did this while it was in the GTO. One thing to note- which might be major - is that in the GTO there was a methanol kit installed. In the 1972 Camaro, there is no meth kit. I just don't get why it's not going into PE mode. I don't believe a tuning shop would disable PE mode somehow just because methanol is being sprayed.
MAP is set to 75kpa, which on the scanner he was at 80kpa and still never left a commanded 1.00 lambda
Log and screen shot below. Tune and screen shot below
Thanks!
Thanks!
Thanks a lot for your help/input btw
Edit: Googling this, I see there might be a PID called "PE TPS". I'll have to see if that is an option. Just seems odd that the PCM wouldn't use normal TPS. I wonder why it uses a different TPS calc. I also read that if I don't have the PID, to just keep decreasing the PE enable TPS until it comes on when I want it to
I'm afraid if we get into it any harder it will grenade the engine. Which throttle position PID should be used? I only see % and voltage as an option to log
NONE of the Gen4 stuff references it that way, drop the PE enable TPS table down to 8 across the board for now and slowly bring it up to find your thresholds that match where you want PE to come on and don't just utilize the MAP enable table. Just be aware that your MAP enable being set to 75 kpa will be the main control with it set to 8 across the board at that point.
Thanks for your help!
