Did my tune get messed up sitting over the winter?
1. A tune doesn't go bad. If the tune is bad it's bad.
2. Speaking generally a stock PCM learns fuel trims and idle air trims, both have short terms and long terms
3. If the car has been tuned, you can disable the long terms and/or also the short terms.
4. You can tune it to run open loop completely, run closed looped, with STFT and or LTFT.
5. Regardless...a tune doesn't go bad...
That part I get and believe. I'm just trying to figure out what happened in the first place. The car has been tuned and had that tune on it when it had its fit. Then I put the same tune on it again and it cleared up like nothing happened. Same temp/same fuel. I just don't want it happening again, maybe when I'm driving it somewhere and don't have my laptop. Probably won't happen again so I guess I'll just wait and see.
The following users liked this post:
G Atsma (03-14-2020)
Now I gotta get my new stall in! Can't wait till the track opens!
Like I said in the title, I don't know what could've happened but I went to start my car after sitting for a couple months and it ran like ****! Pig rich as in 9-10 afr and very bad fumes, misfires, etc. Then my CES came on and when I checked codes got these 3 codes. P0102,P0155,P0045? The one code for the 02 sensor heater could apply but the other 2 codes, 102 is for the maf sensor(I'm running SD now) and the 045 is for Supercharger/turbo boost? I have no idea where this one comes from. I re-flashed it with my tune and it ran fine after that but I was just curious what could cause this to happen? I've never heard of it.
Also when I went to flash it I got a message saying something about operating systems being different and I had to do the "special" flash that said might brick my PCM? Luckily it went fine and didn't brick it but what could be going on here?
MAF failed would cause that P0102 but that is necessary to run in SD. Should be set to "MIL on First Error" and the "SES Enable" box should be unchecked. P0101 and P0103 should be set the same way. And "MAF Sensor Frequency Fail High" should be set to 0. What computer are you running? Im not familiar with the P0045 code.
Since it sat for so long, if the battery died, it can lose the codes and STFT/LTFT, requiring you to at least start once to set the code and for it go into SD mode AND THEN you have to relearn LTFTs, if enabled and in closed loop.
Dead battery?
Can you post a copy of your tune file?
Oh, from your earlier question, it's the stock computer.
A little update and I feel like an idiot! My tune didn't get messed up by sitting......I was going through my toolbox and saw my old Diablo Predator in there and remembered that I was trying to "unmarry" it from my car early winter and loaded the stock tune off of it onto my car hoping I could sell the thing! DUH! No wonder it ran like ****!
And the predator sucks....still married to my car and Diablo won't do anything about it unless I have my receipt showing I bought it! Yeah, that was a long time ago and that receipt is in parts unknown now.
#36
a little update and i feel like an idiot! My tune didn't get messed up by sitting......i was going through my toolbox and saw my old diablo predator in there and remembered that i was trying to "unmarry" it from my car early winter and loaded the stock tune off of it onto my car hoping i could sell the thing! Duh! No wonder it ran like ****!
And the predator sucks....still married to my car and diablo won't do anything about it unless i have my receipt showing i bought it! Yeah, that was a long time ago and that receipt is in parts unknown now.
#38
#39
