OS conversion for Flex fuel, lean cruise, ect.
(p01 GM Gen3 V8, 4.3L V6)
Can you simply license the file you found and do a write entire to get the OS from that newer vehicle?
Trying to get a few features into my 1999 that are in a 2002.
Lean cruise, PE ramp in rate, ect.
I'm assuming I'd need to; Write entire back to my stock tune from the 2 bar OS modification it currently has on it.
Then write entire with the tune from the newer vehicle.
And after that I could go ahead and add the 2 bar OS modification back on to the newer OS.
Would this work or not?
I run a 02 OS on a 99. I did it for the rolling idle tables. I was able to get lean cruise to work, but when I went full on OLSD I just used the VE and multiplier tables to make it lean in the cruising ranges.
so there was no re-pining anything in the harnesses?
What about VATS? Did you have to do the re learn procedure or was it not an issue?
