Predator Diablo Sport Tuner
Old Mar 22, 2020 | 02:58 PM
Mezzy's Avatar
Default Predator Diablo Sport Tuner
I have Predator Diablo Sport Tuner that I need a charger for. Does anyone know where to find one?
Old Mar 23, 2020 | 09:07 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Yikes, thats an oldie
Before you go spend money, whats your plan?
That device is not internet update-able, and is rather limited in its ability.
Old Mar 23, 2020 | 09:10 AM
Mezzy's Avatar
I just wanted to see if I could get extra hp from the vehicle using the tuner
Old Mar 23, 2020 | 01:10 PM
06MonteSS's Avatar
LS1Tech Sponsor
just connect it to your vehicle.. no power cord needed, it gets its power from the OBD port in the vehicle..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 26, 2020 | 01:10 PM
DuckDude's Avatar
Did it work?
If you NEED a charger (I have no clue if that thing really needs a charger) look on the tuner and see what its voltage and amp input and output are, then you can find a charger with the correct plug that has those similar voltage and amps output. If you give it too many amps (more than likely milliamps, or mA) during the charge, it'll charge too fast and the charge wont last long. And you could ruin the tuner.
Old Mar 28, 2020 | 03:12 PM
06MonteSS's Avatar
LS1Tech Sponsor
the charger is only needed to give it power for when connecting to a PC.. but that olllllld discontinued predator can not do internet updates or custom tuning anyway.. so no need for a power cord... there is nothing to "charge"... just connect it to your OBD port in the vehicle.. it will get it's power from the obd port and allow you to install a tune, scan for codes, etc..
__________________
Old Jun 11, 2020 | 03:11 PM
MonteSS314's Avatar
hey 06montess I had just purchased a 06 monte ss myself and was wondering if u could help with a tune doing dod delete ls7 lifters non afm cam truck intake and fender intake I got the u7191 my email gmfb314@gmail.com thanks
Old Jun 14, 2020 | 06:36 PM
06MonteSS's Avatar
LS1Tech Sponsor
I don't do tuning for those olllld dead predator's anymore... can't do any transmission tuning with it, limited settings/adjustments, etc...
I would suggest that you restore the original backup stock factory tune to the car... then contact diablosport about trading in that ollllld dead predator to them... and they will give you a $100 discount on buying the new inTune i3 8245 Platinum version programmer from them (that's the model you need for custom tuning)... and then yes, I could definitely do a custom tune for you and your car....
Once you do that, you can email me directly at: diablo DOT help AT gmail DOT com
and then I can definitely get you hooked up...
-Lew
- aka 06MonteSS
__________________
