holley 2 step with pressure sensor
Old Apr 19, 2020 | 08:40 AM
TrendSetter's Avatar
Default holley 2 step with pressure sensor
I dont have an account on the holley board so im posting here.
My car is converted to manual from auto, using a hydraulic clutch setup. rather than figure out some form of clutch switch im planning to install a pressure sensor in the clutch line. I am looking at my holley software and i cant figure out how to activate a proper 2 step using a pressure sensor, only with a ecu pin input ground or +12. i can also see where you can fully cut ignition but i dont want that, i want a set rpm limit for spooling the turbo.
its a terminator x non dbw ecm
i guess i could physically tie an ecm output to an input but this stupid thing has such limited io id rather actually do it in software.
