Misfire in boost
Hey guys, I have a 99 ls1 stock motor with a huron v1 kit, racetronix 340 pump with regulator and return, with 80lb injectors. Running 8lb wastegate spring. Car ran great for 100 miles, and then lost almost all power on a 2nd gear pull as soon as I got into boost. Drove fine other than that, replaced plugs, wires, and crank sensor. Same issue, seems to be just hesitating in 3rd gear at 4k rpm. Last night, it sat for 15 minutes after it acted up and then would not start at all. Ate dinner, and it started fine. 60 psi at the fuel rail, and pump is working fine. Air fuels are good until it misfires. No dtcs, and does not act up when revving in park. Any ideas? I have attached a log.
