E85 LS1 Turbo startup tune issue
Hi,
I'm new to HP tuners and I'm currently trying to setup a base startup tune for my single turbo E85 LS1
LS1 has the following parts
2BAR map
Maff disabled
1000cc injectors - injector data has been setup as per instruction's with injectors.
rising rate FPR
VCM264 cam specs are:-
287 intake 278 exhaust
232 intake 226 exhaust duration @ .050"
.591" intake .598" exhaust lift
lobe sep 114"
Stoich 9.71 added 15% more fuel to VE table
will attach map file and a log file. Log file won't be much tho...
I'm unsure if the 15% more fuel is causing issues or more adjustment needed to suit cam?
any help or pointers would be much appreciated.
2BAR map
Maff disabled
rising rate FPR
lobe sep 114"
