Instruments go haywire, momentary power loss on hard launch !
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
First race this year, car ran fine off the trailer, normal performance. Second run about 10ft out sudden power loss, instruments haywire and warning lamps flashing, lasted about 1 or 2 seconds then car took off as if nothing happened through rest of the run. I checked the obvious, battery terminals , alternator charge ( no load ) checked for bad grounds that I could find......nothing. Took it out on the street and wheel spun but ran fine, back on the track with good traction and positive hook .... same thing ????? Anybody had this happen or any suggestions, Thanks in Advance
2000 Camaro LS1 , A4, stock heads and cam, long tubes, 2800 stall etc. bolt ons only!
Check all connections.
The following users liked this post:
alank1953 (05-05-2020)
My car was/ is doing something similar on full-throttle pulls (instrument cluster goes dead, A/C blower stops working, exterior lights turn off).
Alternator regulator is wigging out at high rpms.
I hooked a jumper wire to my alternator stud, then ran it into the car where my DVOM was.
Sure enough, once I got to 5K, voltage jumped to 18V, and everything started acting weird.
I'd check that out.
I'd check that out.
Absolutely correct........................Thank you
That was the problem, The battery bottom clamp was tight, but the battery could still rock back and short on the A/C Filter dryer bracket !
THANK YOU EVERYONE FOR YOUR INPUT .
