Backfiring and no power P0102
Old May 29, 2020 | 12:10 PM
68roadrunner's Avatar
Default Backfiring and no power P0102
Guys I am having issues with my gen III Ls swap. It has run great for 5,000 miles...now it is...
Backfiring at idle and off idle
No power
Replaced wires, plugs and coil
Has one code P0102
Injectors and oxygen sensor replaced
5.3/4.8 ls engine high mileage motor out of a suburban
55 psi at the fuel rail
Psi conversion ECM tune
new injectors
any suggestions ?
Old May 29, 2020 | 12:23 PM
Have you looked up code P0102? "Mass Air Low Voltage Input"
Check all circuits to and from the MAF sensor.
While you're at it check all grounds.
Old Jun 1, 2020 | 11:08 AM
LilJayV10's Avatar
a tune and data log would be helpful.....
There could be an issue with the MAF or the wiring.
The MAF could also be failed in the tune intentionally to force speed density. If so, it will through that code also.
Without a log and tune, everyone is just going to be guessing.
