Stall when coming to a stop
Old May 29, 2020 | 06:22 PM
dicolanl's Avatar
Default Stall when coming to a stop
67 Nova swapped in a 2003 LQ4 / 4L85E.
Finishing the build and took it out for a test drive. Coming to a stop or slowing to make a right hand it stalled out on me. had to tap the gas to keep it running
I noticed when I had to move it around the garage before and tapped the gas it did it once or twice too.
Attached my tune from VCM.
Any ideas what might be causing the stall out???
File Type: hpt
Old May 29, 2020 | 06:25 PM
Idle speed?
Stock cam?
Old May 30, 2020 | 04:45 PM
mrvedit's Avatar
Moderator
An idle of 575 with even a modest performance cam is very low. Try increasing anything under 650 to 650.
If your VE table is stock too, we may have to tweak that a bit too.
BTW - I deleted your two duplicate posts. NP.
Old May 30, 2020 | 04:56 PM
B52bombardier1's Avatar
There should be a "stall saver" RPM setting in your tune that you could adjust. But yea, 650 is also what I like for an RPM.
Rick
Old May 30, 2020 | 05:03 PM
dicolanl's Avatar
Awesome thanks. I’ll try taking it up a bit.
Old Jun 1, 2020 | 12:52 PM
LetsTurboSomething's Avatar
It's hard to give good answers without a scan where it stalls a couple times. Need to see things like idle motor counts, the over/under speed of the idle, etc...
But from looking at the tune...I don't think the throttle cracker functions right when its engage and disengage speed are set to the same number. Try setting the disable speed to 3mph and leave the enable at 2mph and see if that doesn't help.
Old Jun 1, 2020 | 12:53 PM
dicolanl's Avatar
Thanks. I’ll take it for a drive and get a scan.
Old Jun 1, 2020 | 01:30 PM
Try the change to the throttle cracker i mentioned before too. That solved this same issue for mine. I had my tune loaded for me before I started because I was new to Hptuners. The throttle cracker disable was set to 2mph as was the enable speed and it wasn't functioning at all. I looked up a stock tune and the stock tune had the disable set to 3mph and the enable to 2mph. I set the disable to 3mph and it started working. You can hear the engine rev up about 200 rpm the instant the scanner says 2mph as you come to a stop. That was all it took for me.
