Check My Tune
Old Jun 11, 2020 | 09:44 AM
rjb2968's Avatar
Default Check My Tune
Specs:
- Completely Rebuilt 6.0 Liter LQ9 with flat top pistons and ARP rod bolts
- 823 LS3 heads with TSP springs 10.38:1 compression
- TSP 229/244 ..629/.615 112 LSA with 109 ICL
- 1 7/8 Dynatech long tube headers
-Fitech Ultimate LS 70011 with Fitech sheet metal intake
-Monster lightweight flywheel 18lb
-T56 from 04 GTO with 3.73 rear gear
-2nd gen camaro weight approx 3300 lbs
See the attached spark table and AFR.
Old Jun 15, 2020 | 08:53 AM
rjb2968's Avatar
Anyone?
Old Jun 15, 2020 | 06:31 PM
B52bombardier1's Avatar
Some people prefer a log file of the engine running at various RPM, engine load, temperatures and vehicle speeds. It makes for a better analysis of what's actually going on when looking at the tune and log together.
Rick
Old Jun 16, 2020 | 10:58 AM
TrendSetter's Avatar
if those are actual afrs then it seems rich at idle. you can also drop the timing quite a bit at idle if that would help. the afr at wot seems a little on the rich side also. the numbers all look 'ok' but you need to drive it to see what the car likes.
