Good code reading tool for LS1 Newbie?
I did poke around first on the forums, but I don't really know what key words to search for.
I have 2000 Trans-Am I purchased last year with 68,000 on it.
I've been slowly working on it when I can, have not driven it a lot yet.
It's been inspected twice since I've owned it.
The SES light stays on.
The mechanic says it's codes for the catalytic converters and that as long as it's running OK and I drive less than 5000 a year (so exempt from PA emissions), I should ignore it for now.
I'd like to see the codes for myself, and see if I can reset the light and see if it comes right back on, or what I can figure out myself.
Also, thoughts on if this should be ignored or not?
Can someone tell me the best tool(s) for my situation? One that is also capable of resetting the light?
So I can see if the light takes time to come back on, or if it comes back on right away?
Thank you!
Lee
I also have another $70-ish OBD Bluetooth module - OBDLink MX+. It does all of the above with the additional feature of being able to write to the PCM if you ever desire to do your own PCM re-programming.
Rick
Rick
You'll have to decide if this is something you just want to use from time-to-time, or if you want to spend the money on something that will be permanent and gives readings every time you're driving.
