E40 MAP Limit
Old Aug 5, 2020 | 05:14 AM
JoeMama's GTO's Avatar
Default E40 MAP Limit
I am looking to run around 24 psi on an E40 PCM on a 2006 M6 GTO (24x wheel) and was looking to see if there are any tuning tricks to get past the 256 kPa boost limit. I am already running a 2.5 Bar MAP that seems to max out around 21.7 psi. If there are no tricks to tune around it should I look into an external controller like the Microsquirt? I would think all I need to do is control the injectors via the MS and the E40 would just use the timing value from the last cell in the main spark tables. Let me know what you think, thanks in advance,
