LS1 5.3 PCM and LS3 cam sensor?
So I got the engine put together and now I’m looking at the LS3 cam sensor and my LS1 5.3 cam sensor plug. I have a LS3 cam sensor extension harness that converts to an LS1 left over from the fitech EFI that I didn’t need. It plugs right into both the cam and stock harness. I see that wires are flipped on the plus and I read somewhere that’s necessary? Also I heard that the LS1 sensor uses a 12v reference and the LS3 uses a 5v reference? Is that something I need to worry about or should I just plug the LS3 adapter into my stock LS1 harness and just move on?
pics below of the cam sensor and adapter and then adapter to stock LS1 5.3 harness plug. Look at the wire colors.
