LSA Swap - No Start
Old Nov 2, 2020 | 04:11 PM
korndawg's Avatar
Default LSA Swap - No Start
I deleted my previous thread as alot has changed. My tuner sent me a new E67 ECU along w a new tune for my LSA swap into my 1972 Chevelle. Originally I had no spark or fuel but his new tune has fixed that issue. Now the issue is there is no injector pulse. Fuel pump runs/primes, I have spark but the engine just just doesn't fire. I have cranking RPMs showing up. I've attached my current tune along with the VCM scanner whilte trying to start the car. I'm stumped.
File Type: hpt
File Type: hpl
Old Nov 3, 2020 | 12:52 PM
korndawg's Avatar
When i leave the battery disconnected, connect it, it will fire but its for a split second. Then goes back to just cranking. I have attached a new new scan file w more parameters
Old Nov 3, 2020 | 05:31 PM
old guy 44's Avatar
For what it is worth when I installed my L83 and 6l80E in my 63 Pontiac I had similar problems. I do not remember who I used for the first engine loom but they were no help in solving the problem. With the help of my credit card company I sent the whole package back for a refund. Purchased a Howell loom and had them do a bench tune on the ECM. Plugged everything in, turned the key and presto. It has been running for a year now and I am looking for someone to do a "tweak and peak" on the ECM for a couple of glitches, but would not be scared to fill the tank and head for the east coast just the way it sits.
Old Nov 4, 2020 | 07:40 AM
korndawg's Avatar
I'm starting to think my harness might be apart of my issue too. He's done a few things so far we've found that makes no sense and his support is meh. Refuses to send us a wiring diagram/pinout of his harness that would help w the TS. Forum sponsor here so I won't say who.
Old Nov 4, 2020 | 12:08 PM
old guy 44's Avatar
I believe that my issue was the sensors in the front of the engine. Not familiar enough with the system to know what they are but there are three of them essentially in front of the camshaft. My original loom had a wrong connector to one of them and I had to build a jumper because the supplier kept promising but not delivering. The Howell loom plugged right in and I connected the 5 or 6 wires that needed to be tied into the original loom and it fired first time. The only problem I have had since was the frame mounted high pressure pump. Ordered a Walboro and they delivered a Chinese knock off which died within abut 5,000 mi.
Old Nov 4, 2020 | 11:35 PM
Mickyinks's Avatar
Sounds like your crank angle sensor. I stuffed around with what seems like same issue as your having, tried everything, , on the third new crank angle sensor away it went
Old Nov 5, 2020 | 10:31 AM
korndawg's Avatar
So the tuner left "Starter Fault Check" enabled. I disabled it and it fired right up. Still some fine tuning issues to try to figure out but atleast its running!
Old Nov 5, 2020 | 11:33 AM
old guy 44's Avatar
Always a good feeling, congrats.
