MAP sensor reading off? 1 or 2 bar
My understanding is that the van would use a 1 bar map since it was N/A and based on research of the P/N 09359409 and the fact that the factory settings were linear 94.43 and offset 10.34 i believed it was a 1 bar map. Since im turbocharged now i knew i would need to upgrade to a 2 bar map at minimum.
I was getting 102 kpa with key on engine off on the VCM scanner at about 60kpa at idle to do some idle tuning which worked and pushed me more to believe it was a 1 bar map.
I wanted to do some road tuning and didnt want to chance getting into boost on a 1 bar map so i switched over to the 2bar os and installed a new map sensor P/N 12614970 which was suposed to be a 2 bar sensor with linear 200 and offset 10.34 settings and got 205kpa on the scanner with key on engine off.
So that led me to check the voltage on the new map which was 4.8v key on engine off. The original map was about 2.6v key on engine off which makes me believe i had a 2 bar in the first place.
Ive done about 20 hours looking around various forums and sites and accepted that the new map i bought is a 1 bar because of the 4.8v key on engine off and im out of that money but this brings the question.
Why would that map sensor show 100 kpa on the scanner key on engine off with 94.43 linear (5v) and 10.34 offset (0v) with 2.5 volts? Shouldnt it have shown around 55-65kpa at 2.5v with the linear and offset settings?
https://ls1tech.com/forums/forced-in...ap-sensor.html
https://forum.hptuners.com/showthrea...-MAP-KOEO-0kPa.
Based on link it's my understanding that with KOEO (key on engine off) you don't get a reading (zero). For example: my tuner kept arguing with me that my 2 bar map was defective and wouldn't put the car on the dyno until I replaced the map sensor. Since I have a 98 my OS had been converted to the HP Tuners custom OS for 98 only OS.
He was wrong, the 2 bar map sensor reads correctly with KOEO (key on engine on).
Make sure you have inserted the correct offsets into the tune. In my case I left the settings as they were in the HP OS for a 2 bar map.
KOEO values for anything above a 1-bar in HPT are irrelevant. The 3 bar OS won't even show a kpa reading until the engine is running.
Start the engine, and then see what kpa you're getting at idle.
KOEO 205KPA.
500 rpm cranking 140 kpa.
KOEO 205KPA.
On my LS6 intake, I had to shave off the tab on the 2 bar sensor in order to install the sensor. Since the 2 bar sensor is for a different vehicle and manifold it wouldn't fit on the fbody LS6/LS1 intake manifold. Since I had the intake off when I installed the sensor, it was obvious that I would have to shave off the tab in order to install the sensor. Not so obvious if the intake manifold is installed on the engine.
Some sensors contain the orange rubber grommet on the neck of the sensor when you purchase the sensor. Some do NOT and it is optional. You can use the grommet from the stock sensor if you carefully remove it without splitting the grommet. The sensor must have the grommet before installing.
KPA is intake engine manifold vacuum. I doubt seriously that when the engine is cranking that it is creating 140 KPA.
Link to identify map sensors
https://www.robietherobot.com/storm/mapsensor.htm
GM made a sensor for the Cobalt SS that was a 2.5 bar, plug and play with your orig GM Camaro harness.
GM also makes a 3 bar for the LS9 that is excellent. Not plug and play, need a pig tail, and rewire.
Why did you put a later ECU in your Camaro? E38 harness would be wired just fine for the LS9 3 bar sensor.
pretty confusing!
pretty confusing!
I have a 12615136 2 bar sensor coming from the dealership either later today or tomorrow morning. Will post updates once its installed.
Ive visited the website you posted before i created the thread. The voltage chart on the site for 2 bar sensors is what started my confusion as why a 1 bar sensor would put out 2.5v KOEO and show 100kpa on the scanner.
The sensor you ordered is the Cobalt SS sensor. Plug and play with the Gen 3 harness. Not sure about the Gen 4. You might need a pigtail and a small amount of re-wiring.
https://ls1tech.com/forums/pontiac-g...manifolds.html
This a pic of the 2 bar sensor PN 12615136. It does not have a mounting hole to secure it to the manifold but it is tabbed on both sides.
https://www.summitracing.com/parts/ado-213-1631
So dependent on which manifold you have IMO will determine how to secure the map sensor. You do not want the map sensor to blow out under boost if it is not secured.
Some use a clamp like this to secure it to the manifold. You might have to make your own clamp/bracket.
https://www.ebay.com/i/303511103480?...IaAmP0EALw_wcB
