safe tune for inspection?
Old Jan 15, 2021 | 08:59 AM
z71vortec's Avatar
Default safe tune for inspection?
Im hoping someone can help me out with a safe tune for HP just for an NY inspection... im running the Terminator X and piggy backing the STOCK ecu so ill have gauges and still be able to plug in for the NYS inspection. i have a full current performance harness for my blazer so when i get it inspected i can run the harness fully out and drive just a bit to "ready" the monitors to be able to plug in and pass...
6.0
80lb. S Deka's
ls6 manifold
single 88mm turbo...
stock lq4 tb.
4l80e trans with HD2
just simple and safe enough to literally scoot around enough to get the monitors ready. thanks guys if ya can help me out or point me in the right direction!
Old Jan 15, 2021 | 02:46 PM
andy burdess's Avatar
6.0
80lb. S Deka's
ls6 manifold
stock lq4 tb.
I can tune it for you
Old Jan 19, 2021 | 07:37 AM
Mustang Hat'r 2's Avatar
In ny can you just tune off every code? Vin match and no codes it should pass correct?
Old Jan 19, 2021 | 03:45 PM
z71vortec's Avatar
i know you can turn off rear O2 sensors and emissions... im not sure if you can turn everything off and then it will pass... doesnt the vehicle have to be running while they plug it in?
Old Jan 19, 2021 | 04:32 PM
RedXray's Avatar
In HP Tuners you can turn off the DTC codes to "No Error Reported". Not sure if different states testing equipment can detect the code reporting has been altered. I live in a free state that has no emissions testing. In HP Tuners software where the codes can be turned on/off it says:
Originally Posted by HP Tuners
Master DTC List: Tampering with emissions control devices can be illegal. Please check your local laws as well as EPA rules and regulations for legal modification. Disabling emissions controls should be used on off road use only vehicles. It is illegal to modify diagnostic test results in order to pass emissions testing. FOR OFF ROAD USE ONLY!
