WOT Surge Issue Please HELP
Old Feb 6, 2021 | 08:39 PM
golson's Avatar
Default WOT Surge Issue Please HELP
Hello members. Please help if you can. I am kind of getting frustrated sending my car to tuners and still have issues. So I will say I have a LS7 swap in an RX-7. I took my car to two tuners and seems like it pulls well on the dyno but when I drive the vehicle at home i get a surging problem in the engine at WOT around higher power band only. it just so happens the tuner I trust is about two hours away and can't just take it over for him to do data logging due to his schedule. I know this is not too detailed for the smart people here but any advice on troubleshooting would help. I am totally pissed i cannot drive my car properly and have no where else to turn to right now. Thanks folks please let me know...
V/R
Greg Olson
Old Feb 6, 2021 | 08:43 PM
AgFormula02's Avatar
V/R
Greg Olson
any way to log it while driving?
could be a few things.
fuel comes to mind. Pick up being exposed. Also fuel consumption under load while driving can be different than that on a dyno.
share more details on what it is doing.
DBC or DBW?
could it be picking up some knock ?
Old Feb 6, 2021 | 08:52 PM
golson's Avatar
DBC or DBW?
Only logging software i have is ToadScan. Would that work?
Old Feb 7, 2021 | 12:15 PM
RonSSNova's Avatar
What you really want to see is AFR with a wideband O2 meter.
Dyno obviously is stationary. And a dyno pull is relatively short duration.
The road is totally different.
What does the fuel system consist of?
Old Feb 7, 2021 | 12:22 PM
golson's Avatar
I have a close neghbor getting HPtuners in a few days to log data. My fuel system is a Walbro 450 pump and constant fuel pressure at 60psi with 93 octane. No lag in pressure when WOT either. I was going to replace the fuel filter just to be safe but if the pressure is constant i see no reason the filter is clogged or dirty. I might replace the plugs but will that be necessary?
Old Feb 7, 2021 | 01:03 PM
rpturbo's Avatar
Curious how you know there is no lag in pressure or volume when you're not data logging it? Is the tank say, at least 1/2 full or more? If I have just a tad under a half tank, I can get my truck to get a lean spike on a hard pull when the fuel sloshes.
A gauge isn't sensitive enough to show the story, because of latiency.
Old Feb 7, 2021 | 01:11 PM
golson's Avatar
Well taking it to two tuners I am sure they knew what to look at. I described the same issue with them. There was a lean issue during the last tune and he fixed that issue.
Old Feb 8, 2021 | 07:30 AM
Old Geezer's Avatar
"Well taking it to two tuners I am sure they knew what to look at" ?
Old Feb 8, 2021 | 11:01 AM
smokeshow's Avatar
Can't really recommend anything without seeing it in action... Need some sort of data.
Old Feb 8, 2021 | 11:02 AM
golson's Avatar
Yea. I am going to record data this week.
Old Sep 2, 2021 | 08:34 AM
golson's Avatar
Hello everyone. It has been a while but I like to give an update and provide some additional data. It was recommended from a few folks to install a surge tank and increase the fuel line size. Well I did that and put two surge pumps with plenty of volume. The hesitation was still present and I am at a lost of what to troubleshoot. I don't want to keep sinking money in this as anyone would understand. So, a friend of mine recorded three runs on HP tuners with the hesitation. Could some of you folks please look at these data logs and try to help me out? If I don't get it resolved soon, I will most likely sell the car...At least that is how frustrated i am.
File Type: hpl
File Type: hpl
File Type: hpl
Old Sep 2, 2021 | 10:46 AM
minytrker's Avatar
Need a wideband connected to hp tuners to see whay your air fuel is while WOT. Your fuel trims part throttle don't look bad.
Old Sep 2, 2021 | 11:33 AM
golson's Avatar
Is there a way to do this safely while driving? My car does not do the surging/hesitation on Dyno.
Old Sep 2, 2021 | 01:46 PM
minytrker's Avatar
What kind of dyno do they have? Does it have a load cell? We take cars straight off the dyno and run through through 1/4 mile and also through the mile but our dyno has a load cell. If there dyno is inertia only then your only option is on the street or a track.
Old Sep 2, 2021 | 02:14 PM
golson's Avatar
Understood but what would be the difference data logging using a dyno under load and driving the vehicle? Do I need to data log something different?
Old Sep 2, 2021 | 02:42 PM
A loaded dyno can vary the load under measured and controlled conditions, which is more difficult under driving conditions.
Old Sep 2, 2021 | 03:19 PM
minytrker's Avatar
If there dyno isnt loaded then you can get different results on the dyno vs the street. If its loaded then they can duplicate driving on the street.
Old Sep 2, 2021 | 03:34 PM
golson's Avatar
Ok I am tracking that but what am i specifically looking for on the dyno? Doesn't my data logs have enough data?
Old Sep 2, 2021 | 07:33 PM
LilJayV10's Avatar
Listen to what people are telling you.
Old Sep 2, 2021 | 09:16 PM
golson's Avatar
Ok will try to get this done in a couple days
