Replaced Throttle Body - setting the blade (verify I am doing this right)
The car was already tuned with a Nick Williams 102mm throttle body. I replaced the throttle body with a Mamo Nick Williams 102mm throttle body. Now, I need to adjust the set screw.
Since the car was already tuned for a Nick Williams 102mm throttle body, all I should need to do is adjust the set-screw until the TPS is @.64V and IAC steps are @55 at hot idle, correct?
