Map sensor drop at 5000 rpms
Old Feb 13, 2021 | 12:34 PM
Hash123's Avatar
Default Map sensor drop at 5000 rpms
Hey guys new member here! I hope im in the right section.
i own a camaro MY2000 and recently swapped an ls3 in it with a maf delete.
Engine modds:
stock bottom stock heads
TSP f35 stage 4 cam
TSP pushrods 7.4350
TSP .660 springs
did all the required extentions for the sensor and got no codes on HP tuner.
my issue is.. car run perfectly fine up to 5000rpm, The map sensor reading and voltage drops from 5V to 1V and from 100 map sensor reading on HPtuner to almost nothing.
i am not being able to dyno the car.
things done:
changed 3 map sensors
checked all wirings with ohm meter
changed ecu
even checked 3 pushrod different lengths
Appreciate any help i could get guys!
thanks,
Hash
Old Mar 28, 2021 | 02:20 AM
Lethalwx69's Avatar
Engine modds:
TSP f35 stage 4 cam
TSP pushrods 7.4350
TSP .660 springs
things done:
changed ecu
thanks,
Hash
Is the car drive by wire? If so maybe the throttle is shutting.
Old May 2, 2021 | 09:32 AM
ol_granns's Avatar
Did you ever find out what the problem was? I have a similar issue and have tried your troubleshooting with no results.
