Switched from NW 102 TB to Mamo ported NW 102 TB.. AFR on startup is 18-20
I replaced a Nick Williams 102mm throttle body with a Mamo ported Nick Williams 102mm throttle body. I adjusted the set screw until the TPS voltage was bouncing between .63 and .65. Before the swap, the AFR on startup was 12ish, then it would settle at 14-15 after a minute or so. Now, the AFR on startup is 19ish, then settles at 14-15 after a minute or so. I have not been driving until the AFR settles to 14-15.
I assume I just need to adjust the set screw to close the throttle blade a little to bring the startup AFR down?
I am getting a new dyno tune in the near future, so I am not even sure if this is anything to worry about.
Have you discussed this with Tony? That would have been my first call....
Have you tried adjusting the open loop EQ ratio (fuel > open loop > base EQ).
You can add more (or less) fuel while while in open loop by adjusting this table and won't effect fueling once you're in closed loop.
